  • pleverell Friend
    #123637
    Firstly, I love the work you do with templates. It makes my life as a web designer/develper so much easier.
    BUT!!
    1. There seems to e a bug on the Larix template on Netscape 7.0 and 7.2 on a MAC. It only appears when in wide screen mode.
    http://www.penn.co.uk/stylecraft
    you will see on the right hand side that each page below the pathway jumps to the right approx 20 px after loading. Hope you can fix this for me or point me in the right direction.
    2. on a MAC with safari 1.3.2 the search in user4 does not display correctly. This can e seen at the same URL
    Hope you can help, keep up the good work
    cheers
    Paul L
    Michael Casha Friend
    #232395
    Hi pleverell,
    Can you please show us a screenshot of the error you’re experiencing? Either upload it to a file host (such as http://www.tinypic.com), or email it to us at webmaster@joomlart.com
    Thanks!
    pleverell Friend
    #232491
    Any news on this problem? I sent you a private message with links to the jpg screen grabs.
    http://www.penn.co.uk/stylecraft/joomlart/
    cheers
    Paul L
This topic contains 3 replies, has 2 voices, and was last updated by  pleverell 17 years, 2 months ago.
