  • MICHAELCVANKIRK Friend
    #118956
    I would like to place a module position above the MainBody and use an image rotator there. How would I do this?
    Cheers,
    Mike
    Khanh Le Moderator
    #215029
    Open template index.php file, search this code:
    <?php mosMainBody(); ?>
    Add following code before above line:
    <?php mosLoadModules ( 'user10' ); ?>
    Now you could publish a module to position user10.
    #215039
    <em>@Khanh Le 8810 wrote:</em><blockquote>Open template index.php file, search this code:
    Now you could publish a module to position user10.</blockquote>
    Thanks! I was loading it wrong.
    sidewalk Friend
    #217610
    Anyone know if I can use this to insert JA header just above the mainBody?? or what image rotator are you using?
    Thanks!
    sidewalk Friend
    #217612
    Actually — i tried it and somehow its cutting the header and messing things up — can someone look see?
    http://www.brantnow.com/facelift/index.php
    I’d really like to place it next to the logo — where would I put the code to have it land just to the right of the logo???
    thanks for your help!!
    ShannonN Friend
    #217620
    sidewalk;12258Actually — i tried it and somehow its cutting the header and messing things up — can someone look see?
    AS a member you may be better suited to use one of the later templates that makes use of the JA header in the standard position below the menus etc ?
    Putting it next to the logo requires a fair bit of customization and I believe wouldn’t compliment the site as the width would have to be cut somewhat due to the size of the logo etc
    For readability sake I’d respectfully suggest losing the reflection on the logo it looks very out of place and in my opinion spoils the logo or if it is a must have shrink the reflection heaps
    Cheers Shannon
    sidewalk Friend
    #217622
    thanks shannon – i sent you a pm –
    dawn
This topic contains 7 replies, has 4 voices, and was last updated by  sidewalk 17 years, 9 months ago.
