  • Sam Samiei Friend
    #935059
    Hi, I’ve created a new module position called "footer-section" and placed it above "navhelper". the module shows in backend and front end.
    there are problems with showing module like "Features Intro"or "[Home] Call To Actions". they don’t show properly if i add them to this position.
    I’ve added the class "enable-effect" for the Page Class field and copied all the codes related to module position "section" to this module as well both in css and php file.
    can anyone please help. thanks
    Hi Sam,
    You can update the login credentials of your site: Admin & FTP account and tell me the file you modified, I will have a look.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 8 years, 6 months ago.
