  • investx Friend
    #152727
    I updated to the new plg_jat3_v1.1.0 and ja_t3_blank_v1.1.1. and I have the following problems:
    1. Template width: SPECIFIED – don’t work anymore ( the auto , wide and narrow work , but if I select SPECIFIED the template width are 980px whatever I put px or percent)
    2. Don’t hide T3 Logo anymore .
    3. It seems that other profiles :blue, fullwidth,..custom .., etc. don’t override the default profile anymore.
    korb Friend
    #350431
    HI,
    IF you are using SPECIFIED width for a certain profile, you must use that profile and reset it once in front-end.
    Danny
    investx Friend
    #350462
    Hi Korb,
    I set the Default Profile SPECIFIED with 100%.
    In front-end I select the default profile with Fullwidth screen but as you can see my site have only 95%.:((:((
    Check on my site please. Before the update it worked very well .
    Also it seems that are other problems too. (can’t hide the logo anymore)
    Also in joomla back-end extension manager after I install the new template appear a line with a blank template..
    investx Friend
    #350529
    It seems that nobody has installed the new versions and nobody can help me :((:((:((
    I will still wait maybe somebody from the JA staff will check this problems.
    Khanh Le Moderator
    #350854
    T3v2 framework is under beta version and we release new versions often to fix such those bugs. Please update the Framework as well as the template to resolve above issues.
    Thanks,
    Khanh Le
This topic contains 5 replies, has 3 voices, and was last updated by  Khanh Le 14 years, 5 months ago.
