  • cwilborngv Friend
    #175687
    When navigating directly to the site (http://beta.gazettevirginian.com/) the headlines in the News Pro module aren’t spaced properly (see sample01) … the headlines are cutoff at the bottom.
    However, when clicking on the home button at the top, then module seems spaced properly (see sample02).
    How can I get it where when a user navigates directly to the site the module appears correctly?
    1. sample01
    2. sample02
    TomC Moderator
    #446893
    What is odd is that it the “spacing” issue is occurring (when I view your site in Google Chrome) with the “.com” address …. but when it is viewed with “.com/index.php”, the spacing is fine.
    Also, when I view your site in FireFox either way, the spacing is fine.
    Which browser do you use primarily?
    cwilborngv Friend
    #446894
    Google Chrome, but also see that it does the same thing in Safari….
    cwilborngv Friend
    #448728
    Any additional thoughts on this? I’m seeing it in all browsers.
    Ninja Lead Moderator
    #449661
    <em>@cwilborngv 311737 wrote:</em><blockquote>When navigating directly to the site (http://beta.gazettevirginian.com/) the headlines in the News Pro module aren’t spaced properly (see sample01) … the headlines are cutoff at the bottom.
    How can I get it where when a user navigates directly to the site the module appears correctly?</blockquote>
    Yes, i see this error and need login information on your site. please PM to me username/password and FTP account. I will fix it on your site.
    cwilborngv Friend
    #450131
    My site has been moved to a new server to prepare for a launch next week. I”ve sent you details in a private message.
    Do you know what’s causing this issue? Can you get it fixed for me??
    Thanks!!!
    cwilborngv Friend
    #450160
    Any additional thoughts on this? It’s really the only thing left that’s aggravating me! 🙂
    #450225
    <em>@cwilborngv 316000 wrote:</em><blockquote>My site has been moved to a new server to prepare for a launch next week. I”ve sent you details in a private message.
    Thanks!!!</blockquote>
    yes, I have forwarded to dev’s team and they’re working on the error on your site. Will let you know when it is fixed.
    cwilborngv Friend
    #450237
    Thanks! 🙂
    #450311
    Problem on your site is fixed. Please check it again.
    cwilborngv Friend
    #450315
    Now it appears the photos in the NewsPro module are shifted to the left … can that be fixed??
    #450514
    Yes, you can do that. <blockquote>Go to admin site -> Module Manager-> select type ->JA News Pro Module->edit 02 JA News Pro Module and change small size of Image Width, Image Height and align left, right if you like</blockquote>
This topic contains 12 replies, has 3 voices, and was last updated by  Ninja Lead 12 years, 7 months ago.
