Viewing 15 posts - 1 through 15 (of 17 total)
  • sushismb Friend
    #173604
    I just installed the default newsfeed module on the newly installed Joomla1.7 with JA Edenite template.
    I see that the feeds have left margins with a “dot”, which looks quite ugly. I’d like to adjust the margin and remove the dot.
    I tried to firebug but couldn’t pinpoint which file to edit/revise.
    I’d appreciate for any help.
    Thank you very much in advance!
    khoand Friend
    #437193
    Could you give me a link to your site?
    sushismb Friend
    #437210
    Hi khoand,
    Unfortunately, it’s an offline site I’m working on. But I’m sure you can figure how the syndicate looks like.
    It has a margin on the left side with a black dot. Which i both would like to edit/remove.
    Thanks!
    khoand Friend
    #437722
    Could you give me a snapshot of your website? I will try to help you.
    sushismb Friend
    #439669
    Please see the attached image… I want to remove the indent and the bullet.
    Which file should I edit to remove these?
    Thanks in advance!
    1. icube_bullets
    khoand Friend
    #439966
    I can’t see it on my localhost. So, I can’t help you. When you publish your website, you inform me and I will help you fix it.
    sushismb Friend
    #440006
    Hello khoand,
    You don’t see the attached image?
    If you do see it, it’s about removing the indent and the black bullet dot.
    khoand Friend
    #440007
    I see it. But I need to view your website directly to use firebug detect what happened. I can’t fix it if I just see image.
    khoand Friend
    #440019
    There is a snapshot of my website use newsfeed, it has no problem.
    1. newsfeed
    khoand Friend
    #440124
    You add the code into /template/your_template/css/template.css
    .column ul li.newsfeed-item {
    background: none;
    sushismb Friend
    #440160
    Hello khoand,
    That removed the black button! Thanks!
    One more thing, I need to remove the indent. How do I do that? I removed the “ul” but that didn’t seem to work.
    khoand Friend
    #440320
    You replace the code
    background: none;
    with
    background: none;
    padding-left: 0px;
    ruenskomat Friend
    #440842
    Hello khoand,
    I had the same problem and your solutions were very helpful. But in my case there is still a lot of space between the feeds. How is it possible to reduce them?
    Greetings,
    khoand Friend
    #440880
    <em>@ruenskomat 303867 wrote:</em><blockquote>Hello khoand,
    Greetings,</blockquote>
    Could you give me a link to your page has issue? I will check it.
    ruenskomat Friend
    #440977
    my page is http://62.75.216.45/
    The Feed is on the down right.
This topic contains 17 replies, has 3 voices, and was last updated by  ruenskomat 12 years, 8 months ago.
