  • dcasmr Friend
    #176337
    I want to be able to publish a module in position col-mass-top or bottom that will show newsflash. Is it possible with the JANewsflash module? I need help with changing sizes.
    #449880
    Hi dcasmr,
    I think it’s possible, you can publish a module at any position you want. What exactly is the size you want to change to? Please provide more details / screenshots or live site url so that we can help to set the same for you.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 12 years, 8 months ago.
