  • katew Friend
    #138472
    Hi There
    I just created a site using lolite ( http://dev.capitalreach.org/ ) I installed the newsflash plugin and everything was working great until I turned on the SEO urls in the global configuration.
    With SEO on – the Newflash will not display my images it will only display my image title. Does anyone know how to fix this issue?
    Thanks in advance.
    andreipopel Friend
    #293386
    I have the same problem, when I enable SEO…no more images in newsflash, only image titles
    Is there a latest ja_newsflash module?
    andreipopel Friend
    #293394
    The ja_newsflash module installed on any other template, not only ja templates, has this error when seo url is enabled. >:(
    Joomlart, please repair this module!
    katew Friend
    #293396
    I don’t think that the JA Newsflash is the issue. I have built another site using JA Quillija template http://www.constructionchallenge.org/ and I have SEO turned on and my newsflash works great. It must be an error in the Lolite template.
    katew Friend
    #293842
    Hi andreipopel
    I just figured out the setting that was diffent on my two sites. For the JA Newsflash module to work with SEF enabled you need to enable Legacy Mode. (Plugin Manager>System-Legacy)
    If anyone knows how to get it running in native 1.5.9 please let me know. Thanks.
    andreipopel Friend
    #293858
    Oh yeaaaah, Joomlart rulsz :)) Why do I have to enable legacy mode for a…common guys, is this a proffesional template or are you playing with our nerves?
This topic contains 6 replies, has 2 voices, and was last updated by  andreipopel 15 years, 10 months ago.
