September 20, 2010 at 2:06 pm #154475
I have two issue on a site that is due to go live shortly.
1. In IE 7 & 8 the navigation drop-downs are transparent when they should be blue as per your design.
2. The Homepage takes quite a long time to appear. I have had three people tell me the same thing.
The staging URL is : http://protagonist-staging.com/protagonist-staging/index.php
I would be grateful if you could come back to me urgently on this.
Many thanks
Oliver
Saguaros ModeratorSaguaros
September 21, 2010 at 9:14 am #356238Hello
The menu works well without any problem on my pc.
with issue 2, i think that the problem is from your server: slow and php restricting configuration, or something else. You can try to use extensions for compressing or combining css, and test this issue again, may be then it will be faster +)
September 21, 2010 at 11:37 am #356248Thanks for your reply.
There is definitely an issue with IE 7 & 8 the navigation drop-downs, they are transparent when they should be blue as per your design.
Please can you test with these, this is a serious issue that is affecting the go-live of this site.
Oliver
September 22, 2010 at 4:07 am #356321<em>@protagonist21 194923 wrote:</em><blockquote>Thanks for your reply.
Oliver</blockquote>
Sure, this morning, i have testd the site on IE again. the site works more quickly than yesterday :),
With joomla site: when you have completed all development, you will need to improve, optimize the joomla site to speed up the performance of the site at the next steps.
You can refer to some entries for more guidelines: http://www.joomlahostingreviews.com/best-practices/want-to-make-joomla-faster-start-here.html and http://www.siteground.com/tutorials/websiteperformance/joomla15.htmSeptember 24, 2010 at 9:23 am #356549AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by protagonist21 13 years, 12 months ago.
NICKEL – Browser issue with Internet Explorer 8 and 7 & speed of homepage load
