  • ronron6 Friend
    #974912
    hi
    article title is missing despite setting the title to show on both article manager options and edit article options.
    what can i do?
    also the layout for the rating is now good, what could be the problem?
    thanks
    version of Purity III! Your version is 1.1.2
    version of T3 Framework! is 2.4.8
    1. Screenshot-article-notitle-cle
    Pankaj Sharma Moderator
    #974940
    In this case , i need to take a look on your site , kindly send me a temp. super user details via Private reply .
    ronron6 Friend
    #975079
    hi
    can you guide me on what to check for?
    too many work on going the site…
    thanks
    #975157
    Kindly take backup of site and update template and T3 plugin to latest version .
    Hope this will solve the problem .
    ronron6 Friend
    #975427
    #975504
    This can be an issue due to wrong customisations , I suggest you remove the custom work from /html/com_content folder that generates the menu output of content(articles,category blog layout etc) .
    Or you can try it on your localhost first and then replace it on the live site .
    Let me know if there is any issue I will help u to fix it .
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 1 month ago.
