worldwebcreator Friend
worldwebcreator
- December 2012
- 4 times in 1 posts
April 25, 2013 at 11:12 am #187069Hi,
I have read this thread:
http://www.joomlart.com/forums/topic/missing-mainbody-content/I believe that is old thread, I searched for “profile” to enable the body content, but I can’t locate the “profile” tab.
Where should I enable the body?
Here is my site link:
http://humanwebsite.com.my/fablous/index.php/company/about-us-
worldwebcreator
- December 2012
April 26, 2013 at 1:59 am #491084Anyone can help? It is urgent.
Saguaros ModeratorSaguaros
April 26, 2013 at 8:14 am #491120Hi,
That thread discusses about the main body content in template used with JAT3 framework. Your current JA Brisk template running with new T3 Framework using style instead of profile. Each style can be assigned with different layout. By default, this template provide 2 layouts: default and home in which home one doesn’t include the main content block.
Hence, if you wanna show body content block, you can simply go to template manager > choose style which uses default layout > Assignment (tab), then assign to every page except for Home page
Wall Crasher DeveloperWall Crasher
- December 2011
- 361 times in 300 posts
April 26, 2013 at 8:23 am #491121Hi worldwebcreator,
Please make sure you have:
1. You should check again if you have choose “home” layout for the “default” template style.
The JA Brisk – Default template style should have “default” layout.
Please verify it by:
– Open Template Manager => JA Brisk – Default
– Active Layout tab
– Very the value of first dropdown. It should be “default”.2. JA Brisk – Default should be the default template style.
If you have select other template style, please switch it back to JA Brisk – Default
If you want to use another theme color, please change them in Theme tab (of JA Brisk – Default)3. Should assign “home” layout to Home menu item.
All JA Brisk – have home layout by default. You can choose any of theme to set to your Home menu item. (Then you should edit JA Brisk – Default theme to match the color scheme, it up to you)If you still have problem. Please provide ftp/admin information. I will invest on your site.
2 users say Thank You to Wall Crasher for this useful post
worldwebcreator Friendworldwebcreator
- December 2012
April 26, 2013 at 8:29 am #491122Here is the problem, if I choose Default Style, it changed to blue color, but I need Orange color with body content.
check this:
http://humanwebsite.com.my/fablous/index.php/products/fablous (Body content does appear, but it changed to blue color).Use “The Brick – Orange” = right color (orange) but no body content
Use “The Brick – Default” = wrong color (blue) but with body contentIt seems that posting on Facebook is even more effective to ask you guy to help compared to post in on your forum.
- December 2012
April 26, 2013 at 8:44 am #491125<em>@Wall Crasher 370550 wrote:</em><blockquote>Hi worldwebcreator,
– Active Layout tab
Regards</blockquote>
Hi Wall, yes your way works. Thanks Wall. 🙂
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 3 voices, and was last updated by worldwebcreator 11 years, 8 months ago.
