  • sergkon Friend
    #159661
    ! can not save can not Add an article from front!
    no editor is not working
    I’m sorry – suffered a website from teltne 2 Teline 4!
    after the transfer – some problems!
    problems problems problems
    No response from tech support!
    Live site doesn’t work’t!!!
    see ticket OBR-433-12796
    Css Magician Friend
    #375345
    Dear sergkon,
    If use com_content, the edit form is ok, but when com_k2 , the edit form is not ok, I think this is k2 problem. Wait me to checking.
    sergkon Friend
    #375376
    solved !
    Thank you
    global21 Friend
    #382510
    I just wondering was your problem that you edit enable for front end in k2 from the globle parameters in k2. If so i have the same issue that i have enable front end editing for k2 (i only run k2 on my site) and there is no edit option showing. If this was the case for you how did you solve this.
    Many thanks in advance.
    anshell Friend
    #383451
    Solved, but how? I have the same problem. Please share.
    global21 Friend
    #383464
    hi there,
    sorry i thought i posted the solution up here, it was bugging the hell out of me and yet it was something simple.
    its down to the k2 groups assigned to the user. standard groups in k2 is 1 rgistered and 2 site owner, you can setup more. you will need to go into k2 and change the assign to who you would like to have edit functions.
    need more help shout me back…..
    anshell Friend
    #383477
    So simple! Thanks a lot!!!! Assign permissions for this group in “Edit user group” at index.php?option=com_k2&view=userGroup&cid=3
This topic contains 7 replies, has 4 voices, and was last updated by  anshell 13 years, 9 months ago.
