  • sonosergio Friend
    #202606
    i think that is more useful insert the string “Search result is null” in body.
    i modify the row 386 in view.html.php in /components/com_jak2filter/views/itemlist but I might have problems with the update of the module
    1. Cattura
    Thanh Nguyen Viet Friend
    #554813
    Thanks you for your suggestion, please share your code so other user can use if need 🙂
This topic contains 2 replies, has 2 voices, and was last updated by  Thanh Nguyen Viet 10 years ago.
