  • agusvgamazo Friend
    #169021
    1)When the users log into my page, the users are not automatically logged into the jobboard.
    I try to import them manually and doesn´t work.
    I have checked and the users are created on the jobboard database table.
    2)The template manager does not allow me to change the settings (ja social).
    3)I can´t remove the Cpanel on the frontend.
    Please help me to fix these problems.
    Thanks in advance
    Manos Moderator
    #415344
    I have tried to login to your site but i keep getting “Invalid Token” So if you have Joomla cache plugin enabled please set it to unpublished, clear your cache and try again!
    Manos
    agusvgamazo Friend
    #415443
    Hi Manos,
    cache already clean and plugin unpublished.
    The problem stay the same.
    Thanks!
    agusvgamazo Friend
    #415447
    If that helps, just to tell you that register works ok with Employers.
    The only problem on register is with candidates.
    jneubauer Friend
    #419788
    has this been resolved yet?
This topic contains 5 replies, has 3 voices, and was last updated by  jneubauer 13 years, 2 months ago.
