February 3, 2012 at 11:31 pm #173523
I have a problem with JAslideshow’s position on homepage. I use another newsslider and i’m unable to see it appear in the slideshow position. Right now, i’m only able to see the title of my module and a white space appears instead of my newsslider.
I’ve unpublished JASlideshow. I also saw that this problem only occurs on the homepage. If i use my newsslider on another page, it’s working in this position.
Can you help please?
pavit Moderatorpavit
February 4, 2012 at 7:44 am #436878Hi
Could you post a link to the page where this problem occurs ?
February 4, 2012 at 6:25 pm #436945I’m building locally, but i’ve managed to put the site online on a temporary domain. You can have a look at : http://sportjeu.com/index.php
If you want to see the working position, just go to http://sportjeu.com/index.php/our-blog
February 4, 2012 at 7:54 pm #436951Hi
Can i ask if the Ja_Slideshow module works on your Home ?
February 4, 2012 at 8:07 pm #436953If i activate it, yes it does.
February 4, 2012 at 8:10 pm #436954Could you update this thread in the first post with the login info for the backend ?
February 4, 2012 at 8:28 pm #436958What do you mean by updating this thread ? As for the login into my backend, i can grant you an access and pm you the login informations.
February 4, 2012 at 8:51 pm #436962Hi
I can see Jquery conflict on your Home caused by the Widgetkit module ( with other modules published on Home page ) , try to ask to the module developers because this is not a joomlart issue the Ja_Slideshow module for example works fine.
February 4, 2012 at 9:39 pm #436969I’m not sure it’s coming from the Widget kit since i’m using the same module on Ironis and don’t have any problem loading it on the main page or on any other page.
This topic contains 9 replies, has 2 voices, and was last updated by magellan456 12 years, 9 months ago.
