alicebb Friend
alicebb
- May 2008
- 5 times in 1 posts
June 7, 2009 at 3:51 pm #141762My problem got marked as Answered. It has not been answered & neither has my other problem with this template
theprofessor Friendtheprofessor
- March 2009
- 64 times in 18 posts
June 7, 2009 at 6:14 pm #307233Can you post your problems again?
alicebb Friendalicebb
- May 2008
June 7, 2009 at 8:03 pm #307255To save me re-typing I will just provide the link to my original porblem statement, the response & my reply. http://www.joomlart.com/forums/topic/installation-problem-ja-transmenu-css-missing/
Although surely it wasn’t so difficult to find as while this thread is titled:
NOT ANSWERED – Installation problem – ja.transmenu.css missing
The original threead is titled
It is also currently the very next thread in the forum listing.
- March 2009
June 7, 2009 at 9:23 pm #307265<em>@alicebb 131895 wrote:</em><blockquote>To save me re-typing I will just provide the link to my original porblem statement, the response & my reply. http://www.joomlart.com/forums/topic/installation-problem-ja-transmenu-css-missing/
It is also currently the very next thread in the forum listing.</blockquote>
Well, considering that 90% of the questions that people ask on here are answered by other members just as yourself, I wouldn’t go about biting the hand that feeds you. >:(1 user says Thank You to theprofessor for this useful post
- May 2008
June 8, 2009 at 8:34 am #307288<em>@theprofessor 131906 wrote:</em><blockquote>Well, considering that 90% of the questions that people ask on here are answered by other members just as yourself, I wouldn’t go about biting the hand that feeds you. >:(</blockquote>My apologies, I was rather grumpy yesterday after a long series of frustrations with Joomla & the final straw was the idiotic ‘ANSWER’ from ‘JA Developer’ who clearly hadn’t even read my original question.
Here is the issue:-
I downloaded the JA Olyra template file but kept getting an error when trying to install it that the file ja.transmenu.css could not be found. I looked in the zip file & that file is indeed missing as it has been renamed to ja.transmenuh.css for some reason.
I downloaded the files again on several different machines both Mac & Windows & unzipped them on several different machines both Mac & Windows & the file is wrongly named in all of the downloads.
I renamed ja_transmenu/ja.transmenuh.css to ja_transmenu/ja.transmenu.css & then the installation was OK.
However I then got to thinking is the problem that the XML file is wrong or that the filename is wrong? Maybe I am just heaping up problems for later with my fix to get it installed.
- May 2008
June 8, 2009 at 8:38 am #307289I just took a look in the Quickstart installation of this template & see that the file ja_transmenu/ja.transmenu.css is totally missing.
So it looks like this template download is totally messed up & perhaps explains the other problem that I have found if I set Template Icon menu to ‘No’ then when I try to access the home page I get the error
Fatal error: Class ‘JA_’ not found in /var/www/pvf/htdocs/templates/ja_olyra/ja_vars.php on line 73
kallan Friendkallan
- August 2006
- 35 times in 1 posts
July 9, 2009 at 3:57 am #310442I think there was just a typo in the xml file as i checked against an older edition and it should be
<filename>ja_transmenu/ja.transmenuh.css</filename>
not
<filename>ja_menus/ja_transmenu/ja.transmenu.css</filename>Regards
Katemfcphil Friendmfcphil
- 388 times in 133 posts
July 9, 2009 at 7:17 am #310454I have removed the ANSWERED on your question
September 3, 2009 at 11:33 pm #316313I have the same install problem. What do I have to do to make it work? Sorry, I am a newb. Thanks!
This topic contains 10 replies, has 6 voices, and was last updated by Anonymous 15 years ago.
