  • georgios Friend
    #1088809
    When a pop up in my website display "www.xxxx say: not found".
    It’s that my API key is not good or it’s my pointer params are KO?
    Thanks for your informations
    Kindly share the credentials of your site and the page where I can see the issue, I will take a look and check for you.
    georgios Friend
    #1089675
    Ok thanks. How can I send this in PM?
    • This reply was modified 6 years, 9 months ago by  georgios.
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 6 years, 9 months ago.
