Pankaj Sharma Moderator
October 28, 2016 at 12:53 am #981186Hi
Could you share a link to your website ?kmgdesign Friendkmgdesign
- October 2013
- 4 times in 3 posts
October 28, 2016 at 7:02 am #981284Its in layoutmodus and not ready! I need to fix it fast for a presentation next week.
Thanks!
October 28, 2016 at 7:17 am #981291Hi
could point the issue with screenshot ?
Here u can see its working fine in the module : http://prntscr.com/czxjrwkmgdesign Friendkmgdesign
- October 2013
October 28, 2016 at 7:22 am #981295did you see it? checked it?
hmmn….
i understand.
thought the pic would scaled also.why not.
this solution/layout is not really successful.the position of the owl controls, (style.css:189) bottom: 120px is to far in the pic.
when i set it to 20px, nothing happened.Thanks!
October 28, 2016 at 7:37 am #981310Hi
In the smaller layout some style changes so the slideshow will adapt the small size view and looks fine .
If you have any issue , you can add the screenshot of the problem and point the issue inside the screenshot , i will help you to make changes .kmgdesign Friendkmgdesign
- October 2013
October 28, 2016 at 7:39 am #981311Thanks for the fast answer.
The position of the owl controls is too high, (style.css:189) bottom: 120px is to far in the pic.
when i set it to 20px, nothing happened.Pankaj Sharma ModeratorPankaj Sharma
October 28, 2016 at 7:59 am #981316Hi
Since you have not posted the screenshot its hard for me to assume the issue .
As per your description i assume you want to change the height of control buttons .
For this either u can add below code in custom.css file.acm-slideshow .owl-carousel .owl-controls { bottom: 20px!important; }
Or go to
/templates/ja_healthcare/local/acm/slideshow/css/themes/rinde/style.css
Find.acm-slideshow .owl-carousel .owl-controls { position: absolute; bottom: 120px;
replace 120 with 20 .
This topic contains 8 replies, has 2 voices, and was last updated by kmgdesign 8 years, 2 months ago.
The topic ‘Not responsive? JA Advanced Custom Module: Slideshow : style-owl’ is closed to new replies.
