Viewing 15 posts - 1 through 15 (of 24 total)
  • pferrol Friend
    #206421
    The module Virtuemart of home products is not working.
    With the sample data when you modify any text stops working and lost settings.
    thank you
    1. Captura-de-pantalla-2015-05-18-a-las-9.27.38
    jooservices Friend
    #570883
    Hi there
    Please provide your site and reproduce steps for inspecting.
    Thank you,
    Viet Vu
    jooservices Friend
    #735945
    Hi there
    Thank you,
    Viet Vu
    pferrol Friend
    #570990
    Is it possible to solve this problem?
    visability Friend
    #570994
    I have had the same issue. Even just opening the module and saving it, without making any changes, destroys the layout of the module on the home page.
    jooservices Friend
    #571002
    <em>@pferrol 473923 wrote:</em><blockquote>Is it possible to solve this problem?</blockquote>
    Hi there
    Please provide more detail & reproduce steps about your issue.
    Your site backend & CPanel access also.
    Thank you,
    Viet Vu
    Css Magician Friend
    #571021
    @pferrol and @visability, if the module Virtuemart of home products is not working, please try to copy file templates/ja_charity/html/grid.php to modules/mod_virtuemart_product/tmpl folder. Sometime VM has error when creating new module layout in template.
    Css Magician Friend
    #736069
    visability Friend
    #571023
    Thank you Viet Vu
    This problem happened when I edited the home page module titled “Shop Good Things ” on the home page. All I did was change the module title and when I saved it the layout was totally changed. The module title also disappeared.
    I thought that I made some error so I created a new install of the quickstart to check my module settings. What I did on the new quckstart site was open the module. Change nothing and save. On save the same issue as the original happened. The layout was broken and the title disappeared.
    You can see the issue here:
    http://www.corporatestyle.co.za/index.php
    Thank you for your help. I will PM you access details.
    visability Friend
    #736071
    Thank you Viet Vu
    pferrol Friend
    #571028
    I send data yesterday but I have no answer.
    Can you please tell me something?
    pferrol Friend
    #736076
    jooservices Friend
    #571035
    Hi there @visability Please create your own topic with issue detail.
    You cause me confuse between your and @pferrol issue.
    Thank you,
    Viet Vu
    jooservices Friend
    #736083
    Thank you,
    Viet Vu
    jooservices Friend
    #571036
    Hi @pferrol
    I got your PM . But still not understand about your issue.
    Please provide your issue in detail and reproduce steps.
    Thank you,
    Viet Vu
This topic contains 24 replies, has 4 voices, and was last updated by  visability 9 years, 7 months ago.
