jooservices Friend
jooservices
- October 2014
- 1245 times in 1121 posts
pferrol Friendpferrol
- 2 times in 1 posts
May 19, 2015 at 7:17 am #571040It’s very simple
If you modify any data you lost Goods Shop module settings and looks as I send you .
No further explanation is not difficult to understand.
I put this in the PMDo you understand ?
Edit module , modified the name and save . It does not work anymorepferrol Friendpferrol
May 19, 2015 at 7:17 am #736088It’s very simple
Edit module , modified the name and save . It does not work anymoreMay 19, 2015 at 7:30 am #571042Hello again Viet
My issue is exactly the same as pferrol. If you find the issue there my issue will also be solved.
May 19, 2015 at 7:30 am #736090Hello again Viet
jooservices Friendjooservices
- October 2014
May 19, 2015 at 8:09 am #571048Hi there @visability For next time please create your own topic with issue detail even they are same thing.
Because it’ll cause confuse and mess up topic .
@pferrol
Please copy file
templatesja_charityhtmlmod_virtuemart_productgrid.php
To
modulesmod_virtuemart_producttmpl
And in backend module choose layout : grid.
Thank you,
Viet Vu1 user says Thank You to jooservices for this useful post
- October 2014
May 19, 2015 at 8:09 am #736096Hi there @visability For next time please create your own topic with issue detail even they are same thing.
@pferrol
Please copy file
To
Thank you,
May 19, 2015 at 8:46 am #571055Thank you Viet Vu
This worked perfectly for me. It has always been my understanding to use forum topics that are relevant to my issue to prevent one issue from being the source of several separate topics. In future I will create a new topic every time if that is how you want it done.
May 19, 2015 at 8:46 am #736103Thank you Viet Vu
This topic contains 24 replies, has 4 voices, and was last updated by visability 9 years, 7 months ago.
