  • tiamat Friend
    #124172
    The template doesn’t work properly with IE.
    Most of images are not displayed and there are problems of transparency.
    Here is my website : http://www.veliberty.fr
    My IE version is 6.0. The website is created with Joomla 1.13.
    Thank you for your help. I do not understand the problem.
    Khanh Le Moderator
    #234025
    Change your livesite_config to http://www.velibery.fr, the transparency for images will work.
This topic contains 2 replies, has 2 voices, and was last updated by  Khanh Le 17 years, 1 month ago.
