  • spitcool Friend
    #149339
    I have recently done some moderate changes to the JA Purity template for a new site I’m building. However, whenever I add enough information into an article for the page to scroll, the footer information (contact info) gets offset upwards on the page and is therefore missing (because it is the same color as the background. Any ideas?? The contact info is supposed to be located at the very bottom in the grey bar.
    http://www.fishonbait.com/cms is the main website, with a specific example at
    http://fishonbait.com/cms/index.php?option=com_content&view=article&id=4:carolinas&catid=13:recreational&Itemid=6
    PS: This site is still under development…
    rich77ard Friend
    #336968
    Sounds like a bit of a tricky one. There’s a site called o-desk where you can hire a virtual programmer to have a look at your site. For a problem like that I’d say you could get it fixed for $10 or maybe even for free. I use them all the time when I have sticky little problems like that. Have you tried looking at your site using different browsers. Sometimes sites look different when looking at them through Firefox and Google etc. Good Luck
This topic contains 2 replies, has 2 voices, and was last updated by  rich77ard 14 years, 8 months ago.
