November 2, 2011 at 7:57 pm #170318
Locally on my LAMP server this template works fine, I do a backup and restore this to my VS and this is the $%^# I get…
http://projects.chrisupchurch.net/nca/index.phpMind you…
I have the exact same OS, DB, PHP Version, and libraries + configuration as my host server.THIS IS DRIVING ME CRAZY. SOMEONE PLEASE HELP!
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
November 2, 2011 at 8:18 pm #422986Who is your webhost ?
November 2, 2011 at 8:24 pm #4229871and1.com. I have about 20 domains there and no problems with any other site. BTW: This also happens on a virtual server and a dedicated server there. One day it’s working and the next…. the whole site is screwed up without any changes being made.
TomC ModeratorTomC
- October 2014
November 2, 2011 at 8:50 pm #422989Seems strange but I cannot imagine that it would be an issue with JA Rasite – as the template has been installed and functional on many different webhost server configurations. So, that leads me to believe that there is something screwy with some configuration somewhere – be it a server configuration or otherwise.
November 2, 2011 at 9:09 pm #422990I’m re-installing (for the 4th time) but this time I’m using the most recent version. Hopefully that will help.
TomC ModeratorTomC
- October 2014
November 2, 2011 at 9:14 pm #422991jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
November 3, 2011 at 6:31 am #423031<em>@cmupchurch 280493 wrote:</em><blockquote>Locally on my LAMP server this template works fine, I do a backup and restore this to my VS and this is the $%^# I get…
I have the exact same OS, DB, PHP Version, and libraries + configuration as my host server.THIS IS DRIVING ME CRAZY. SOMEONE PLEASE HELP!</blockquote>
This is Joomla or relative issue.
Please check with below steps:
<blockquote>- Try to put a php file ( example test.php ) with code
<?php phpinfo() ;?>
In phpinfo page you can find out located of this domain on server.
</blockquote>
<blockquote>- Check physical path of: http://projects.chrisupchurch.net
and make sure your nca is putted under this dir.</blockquote>
<blockquote>
– Remove any htaccess if have to make sure htaccess under
and http://projects.chrisupchurch.net/nca
don’t have any restricted.</blockquote>The most reason of this issue are: ( and we can follow it to find out )
– nca dir is not existed under http://projects.chrisupchurch.net
– htaccess have some restricted.Thank you
Viet Vu -
This topic contains 7 replies, has 3 voices, and was last updated by jooservices 12 years, 10 months ago.
