  • disenbart Friend
    #1008274
    all "Facebook access token Setting" correct
    only Facebook is enabled
    FaceBook ID is correct
    ► Facebook/FaceBook ID/Verify result:
    "data": [
    ► Global/Cron Interval/Run Now result:
    Source : facebook
    Profile Facebook
    Done : 0 Success And 0 Error
    Profile Default
    DONE
    Please help me
    Greetings
    Dietmar
    Hi Dietmar,
    I just tried to verify the ID you put in settings of this plugin but without success, please make sure that you put ID/Name of Facebook Page, not your Facebook Profile
    disenbart Friend
    #1008462
    Hi Saguaros,
    thanks for the tip. Why the plugin don’t work with profil-id?
    regards
    Dietmar
    It depends on how FB supports to get the feed so atm this plugin can only import feeds from FB Page unfortunately.
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 7 years, 10 months ago.
