  • flanagan34 Friend
    #186437
    my website is displayed properly, and I do not understand why.
    I can not update the joomla template via backoffice.
    In addition, it is very slow to display.
    Thank you for your help
    http://www.skillium.fr
    kanenses Friend
    #488862
    -> In my view it appear fine.
    -> First, What version of Joomla you use?
    -> For update template go to:
    -> Components -> Ja Extension Manager
    -> Services Manager: And Setup your Account with Joomlart.
    -> At JA Extension Manager -> Go to “Extensions Manager” -> All Extensions -> Extensions/Components/ TEmplate from Joomlart change from Local Service to Joomlart Updates.
    -> Click on Check Now this will update your Templates/Components.
    -> At your template if you have made any changes backup your files.
    -> Can be because your hosting server have a bad response. Speak with your hosting, you have a bad ping.
    flanagan34 Friend
    #489210
    Thank you for your answer.
    I use joomla 2.5.
    I still can’t update I have that message in the extension manager:
    Warning: Invalid argument supplied for foreach() in /homez.666/skillium/www/administrator/components/com_jaextmanager/helpers/helper.php on line 65…
    and I don’t know where to change the “from Joomlart change from Local Service to Joomlart Updates.”
    You can go to download section of this template, then download > re-install this JA Extension Manager component.
    To change the update service, pls follow this screenshot:
This topic contains 4 replies, has 3 voices, and was last updated by  Saguaros 11 years, 9 months ago.
