test melih
 melih
  • antoniocerasuolo Friend
    #196648
    I have inserted the category blog menu item and sub menu items. but when i click on the main menu item it is showing the last article in the list isnread of the category blog layout.
    this is happening only on this brazilian layout i am drrently configuring.
    can you help?? are you able to see where is the problem??
    this is happening here:
    http://www.relaxdomus.com/index.php/br/
    ciao,
    Antonio
    ps if i remove all the submenus the category blog will show.. but why is this only happening with this language??
    1. for_joomlart_2
    chavan Friend
    #530480
    can you please send me your admin details in PM and provide the exact url of the brazilian language. where you have the issue
    #530511
    <em>@Chavan 421186 wrote:</em><blockquote>can you please send me your admin details in PM and provide the exact url of the brazilian language. where you have the issue</blockquote>
    hi chavan,
    i sent you the details please keep us posted as to your findings.
    and please let me know if you have any other questions?
    ciao,
    Antonio
    #530565
    HI
    I turned “OFF” SEF in global config and now its working!..
    can you please help in nunderstanding how to have this work with SEF turned on?
    ciao
    Antonio
    #530623
    Hi I created a hidden menu and have added the articles to that menu and therefore :
    1) i am able to view in this way the articles int heir own page
    2) i am now able to view correctly the category blog.
    please take a look and let me know if you ahve a better solution
    i ised the REGRAS menu and not the SOLUCOE.. so in the hidden menu you will find all those arricles.
    ciao,
    Antonio
    chavan Friend
    #531540
    Have this solution for a while, If you get a similar error again, Let me know. Will fix things.
    #532505
    hi,
    i was told by my hosting that the following is a malicious file:
    /home/relaxdom/public_html/components/com_content/29nd1a.php [10.0] {Webshell,}
    can i delete this file??
    ciao,
    Antonio
    chavan Friend
    #532630
    yes you can , since I never saw a file named like this in the com_content.
    but download it and save it on the system, for future use. so we can trace a similar files and remove them later.
    #533018
    Hi ,
    I have a problem as you can see here :
    http://www.relaxdomus.com/index.php/br/component/content/article/152-portugues-br/comments-br/178-deixe-comentario-br
    this is missing the menu and the brazilian logo as here on all other pages:
    basically i am accessing an article by clicking on the right hand side : COMENTARIOS, which will take you to the fist link above.
    i added this article to a dummy hidden menu and also on the main menu as unpublished.
    I beleive i have configured correctly on the template…
    can you please help??
    ciao,
    Antonio
    #533560
    <em>@antoniocerasuolo 424460 wrote:</em><blockquote>Hi ,
    ciao,
    Antonio</blockquote>
    can someone please help with this problem?^???
    Ninja Lead Moderator
    #533980
    In this case, you need to create the menu item with Menu Item Type: Single Article or Category Blog which points to “deixe comentario br” article.
    I helped you add B]Menu Item Type[/B]: Single Article directly on your site, for now you click COMENTARIOS and it will be shown the detail page with Portugues(BR) language.
    #533981
    no,
    its ugly!
    i’m taking it out!
    I DONT WANT A menu element!!!
    in fact i added it to the hidden menu.. but its not working!
This topic contains 12 replies, has 3 voices, and was last updated by  antoniocerasuolo 10 years, 9 months ago.
