  • manul Friend
    #175102
    JA Slide Show Module does not work with any type of “Optimize JS” except “NO”
    code is present, but the slides do not show
    is this normal?
    Phill Moderator
    #444191
    It depends on what else you have installed. Certain scripts will not play nicely if you have any type of JS optimization installed. Depending on what the other scripts you have running on your page you may be able to exclude them from the optimization.
This topic contains 2 replies, has 2 voices, and was last updated by  Phill 12 years, 9 months ago.
