  • jaforum Friend
    #190377
    How can I order the articles and the module on the home page in position home-1?
    I know I can order the modules by using grid. But when I have article AND modules on the page then the articles are spread between the modules…
    What I’m trying to achieve is to have 5 modules first and only then the articles start.
    Any ideas?
    phong nam Friend
    #505058
    Hi jaforum,
    On the JA Fixel homepage layout, we do define the grid position which helps users to display the modules in desired order. You can go to Module class suffix in Advanced options of module backend. And put the text grid-pos-x into.
    i.e: The Slideshow module at 1st position, the class suffix will be:
    grid-3×2 grid-pos-1 slideshow
    >> The red text is the grid position order of module.
    bvk1987 Friend
    #505134
    How about the articles spread over de home screen? How can they be ordered? I think that is what jaforum is asking, and me too 😀
    phong nam Friend
    #505158
    Hi all,
    I missed to explain about article order on JA Fixel homepage. The order of articles will depend on the Article order setting in Layout options of menu item (i.e Home).
    soluzionismart Friend
    #508051
    Hi, i’m claudio and i try to apply the solution that you gave as, but i don’t understand where is the “Advanced options of module backend” sorry 🙂
    <em>@Leo Burnetts 388558 wrote:</em><blockquote>Hi jaforum,
    >> The red text is the grid position order of module.</blockquote>
    phong nam Friend
    #508072
    Hi Claudio,
    It seems that this is the first time you work with Joomla CMS. Anyways, just take it easy. I have attached two snapshots of module backend interface on both Joomla 3.x and Joomla 2.5, so that you can find the Advanced Options easily.
    – Joomla 2.5.x
    – Joomla 3.x
    #508099
    thanks a lot. i get it now!
    i also try to resize the module html (facebook) from grid1x1 grid-pos-3 blue to grid2x2 grid-pos-3 blue
    but nothing appen…
    you can see here : http://spazidellanima.soluzionismart.it/
    if you need the access to the site i can give you the access.
    thx
    phong nam Friend
    #508109
    Hi soluzionismart,
    The texts in my recent snapshots maybe make you wrong. Sorry, that is just a sample module backend. The module class suffix should be grid-2×2 , not grid2x2.
    luketsmith Friend
    #509544
    I am new at this but tried this setting before I could get the order to work. Now it finally works. The above setting did not do it for me.
    1. Screenshot-from-2013-10-18-140241
This topic contains 9 replies, has 5 voices, and was last updated by  luketsmith 11 years, 2 months ago.
