  • apan66 Friend
    #157778
    On the frontpage, my products appear randomly, in the “What’s new here” and “Featured products” module.
    How can I place them in my own order and keep them that way?
    Thank you in advance.
    Phan Gam Friend
    #368281
    #1. “What’s new here” modules is mod_ja_vmproductslide module, In this products is ordering by “product_name”.
    If you want to change order field, i think you can make code modification as follows.
    1. Open application.php file in modulesmod_ja_vmproductslideja_vmproductslide folder.
    2. Finding code section
    $query .= ($this->_typeproduct) ? (($this->_typeproduct == 1 ) ? ' AND p.product_special ="Y" ORDER BY p.product_name DESC ' : 'ORDER BY p.cdate DESC ') : 'ORDER BY p.product_name DESC ';
    about line 75
    3. Change ORDER BY field as you want
    #2. You can do the same with module “Featured products”
    Open file mod_virtuemart_featureprod.php in modulesmod_virtuemart_featureprod folder.
    And change sql Order by for get products query.
    Hope that helps
    apan66 Friend
    #368474
    Thank you.
    But I’ve never done this, I really don’t know what to write instead of that code?
    Thank you very much for your effort.
    Phan Gam Friend
    #368699
    Hi apan66,
    You can open website doc root (where locate your website codes) and make to change as my suggestions.
    Regard
This topic contains 4 replies, has 2 voices, and was last updated by  Phan Gam 14 years ago.
