  • playconsole Friend
    #148461
    Hi all,
    First a compliment for the template ja_rasite. For us great and usefull 😎
    For now, we published all “Sections-Categories” in the “Top” module. But something strange happens when we are using another editor in Joomla! other then TynyMCE :confused:
    For now, we resize the pictures to 660×300 and upload the image when creating a new articel (using the standard button – Editor Button – Image, bellow the editor).
    When we publish another editor and add the image link, the picture on the front will showen in full-size:confused:
    Has someone an idea ?
    With regards,
    Vipyammer
    uniquebiz Friend
    #331918
    When you say “other editor” which editor is that? If it is JCE, you may have to use the jce media module and image gallery module etc I think these have to be purchased from JCE dev? The image gallery enables the GD2 resizing and may help. Also check that you have the JCE utilities installed and plugin enabled
This topic contains 2 replies, has 2 voices, and was last updated by  uniquebiz 14 years, 10 months ago.
