  • Karibu Friend
    #120068
    I am experiencing an overLIB 4.10 or later is required fot the Hideform plugin problem in the Admin area. I tried other forums, it was mentioned to clear the cache. Where and how can I do it? Thanks
    ShannonN Friend
    #219490
    topchristian;14669I am experiencing an overLIB 4.10 or later is required fot the Hideform plugin problem in the Admin area. I tried other forums, it was mentioned to clear the cache. Where and how can I do it? Thanks
    If you mean clear the browsers cache? Hold down the ctrl key and hit the reload or refresh button on the browser toolbar, depending on what browsers you use
    that forces the browser to reload everything fresh from the host not reuse stuff stored on the computer, but you knew that 🙂
    ShannonN
    Karibu Friend
    #219513
    Thanks for quick response. Let it come back again, am loaded and I respond appropriately. Thanks
This topic contains 3 replies, has 2 voices, and was last updated by  Karibu 17 years, 7 months ago.
