  • Henning Friend
    #195304
    Hi Guys,
    I’m having a bit of a problem with the width of the template. It seems as though the bottom scroller appears on load although there is nothing displaying on the right side of the site.
    I have gone through all the modules positions as well as the Headers, Footers and Mainnav and I don’t seem to find anything that is overflowing. Please advise.
    Regards,
    Henning
    1. Ja-Beranis-Screenshot
    Nazario A Friend
    #525090
    Hi Henning,
    Please try to open the file: /templates/ja_beranis/css/custom.css and add this rule:
    body {
    overflow-x: hidden;
    Henning Friend
    #525190
    Hi Nazario,
    I was not able to find the custom.css file so instead I added the code to template.css and it worked like a charm. Thanks for the help.
    Regards,
    Henning
    Nazario A Friend
    #525191
    @heninng,
    <blockquote>I was not able to find the custom.css file</blockquote>
    Sorry for not adding note on this. Please create that file in the /templates/ja_beranis/css/ path. All customization you might have under this file will not overridden when you update to new version of template latter on.
    This article will help to understand more on this file:
    http://t3-framework.org/documentation/bs3-customization#custom-css
This topic contains 4 replies, has 2 voices, and was last updated by  Nazario A 10 years, 8 months ago.
