  • praxistotal Friend
    #153857
    Congratulations to this Template FrameWork. But I have a big problem. In My GLOBAL Settings, I just changed the Profile OVERRIDE Settings to another Profile for “All Pages”. But it don´t works.
    For Example -the Settings are switched to the following settings:
    • Google-Fonts
    • Grey Colors
    In the Google-Fonts Profile I made some changes in the Google Font Settings. But the changes aren´t available in the frontend. Leave that OVERRIDE Settings from above and make changes in the “default” Profile, the changes are in the frontend.
    I think, there might be a problem with giving the changes, which are unfortunately not given to the database or where that changes have to be documented.
    praxistotal Friend
    #353860
    I found out something: You take one additional THEME in the SETTINGS in PROFILES. There ist noch Problem. If you take a second one and you change the order, they are shown in the list but aren´t available anymore, so it gets back to the Standrad (blue). So I can´t take more than one additional Color THEME so far. It might be a bug.
    praxistotal Friend
    #353865
    OK. Everything is new installed an the problems are still there. I think we should find a solution as soon as possible.
    Please provide me us the FTP account and the administrator, we would like to check the issue in detail
    praxistotal Friend
    #355646
    Good Morning, we woke up in germany and I made a discovery.
    Yesterday I made some changes. This morning something funny happens. You can believe it or not.
    Every browser ist showing the right override setting for my local template. Only safari shows the default theme. What´s this now?
    Please hurry up to solve my problems.
    descarter Friend
    #359480
    Same with me
    All browsers except safari show my new theme. Safari has defaulted to blue theme
    any thoughts
    steinar Friend
    #359489
    Have you tried emptying the buffer? (Cache)
    marcodeluca Friend
    #359695
    im having the same problem. It’s a clean fresh install from the most recent template, and nothing I do in the template manager changes any settings. I cannot change the colours, themes, or profiles.
    Using the “cPanel” options in the front end I can successfully make these changes. It would be nice if the T3 framework was a little simpler to understand, it kind of sucks having to re-learn how to do basic Joomla functions that I’ve never had a problem with before.
    <em>@praxistotal 194174 wrote:</em><blockquote>Good Morning, we woke up in germany and I made a discovery.
    Please hurry up to solve my problems.</blockquote>
    it’s from the cookies and browser stores previous settings. can you please clear the cookie, browser cache and check this again.
This topic contains 9 replies, has 5 voices, and was last updated by  Saguaros 14 years, 2 months ago.
