  • Stergiou Limited Friend
    #899139
    I have installed the Mono template at https://vigla.net
    The section "our blogs" (front page) uses the module "Articles Category". Although I have adopted the same settings as the demo, and the images are not all portrait, the packery layout is not working.
    I attach a screenshot of the home, and of the settings of the module.
    Ajax is disabled for the home page.
    Can I do something?
    Finally, neither the ‘istotope’ layout is working as the demo
    See the page: https://vigla.net/services (it may not work here, because all images are portrait).
    Is there any recommendation for this?
    Thanks and regards
    Leonidas
    1. Screen-Shot-2016-03-14-at-00.22.48
    2. Screen-Shot-2016-03-14-at-00.30.16
    3. Screen-Shot-2016-03-14-at-00.30.32
    4. Screen-Shot-2016-03-14-at-00.30.39
    Ninja Lead Moderator
    #899304
    Have you sorted out the problem on your site? I checked directly on your site but I see it’s working fine. If you still need to help please give me the screenshot and screenshot what are you trying to do. I will help you to check this
    #900697
    No, I still see 5 images as follows: 4 images in 2 columns and 2 rows, and 1 image in the third col, 1st row. And an empty place on the right of the 5th image (see screenshot 1)
    The demo shows the 5 images to have been "packed" very nice. (see 2)
    Thanks again
    Leonidas
    1. 1-1
    2. 2-1
    #900855
    That is not a bug, if you want to show Double Height or Not, you can make to change JA Extra Fields tab. Please have a look the both images below
    1. Screen-Shot-2016-03-17-at-09.47.03
    2. Screen-Shot-2016-03-17-at-10.16.12
    #900908
    Hello, thank you for the reply.
    I do not have such a tab in my articles editor.
    I suppose that I have not installed a plagin. What is this? Is it the content type?
    Thanks again
    Leonidas
    #901107
    Hi Leonidas,
    That options still exist on your site and you can use it as
    • Go to the category of com_content
    • Under Extra Fields tab and Extra Fields Group: Portfolio
    • Create the new article and select that category and you will see that option above.
    #901149
    Thank you!
    I am blind 🙂
    Leonidas
This topic contains 6 replies, has 2 voices, and was last updated by  Stergiou Limited 8 years, 8 months ago.
