  • thealpha1 Friend
    #137139
    I recently installed the JA Vauxite template, and changed the homepae to show all of the articles (not JA News). In doing so, the ‘More Articles’ links at the bottom return no results, even though 30+ pages are generated. Any ideas?
    anisjolly Friend
    #286625
    Hi thealpha1
    You need to see if the following is selected:
    1) login to your joomla backend
    2) go to your menus and select your main menu
    3) select your homepage
    4) on the right hand side in parameters (advanced), see if your pagination is set to show or auto
    hope this helps.
    thealpha1 Friend
    #286647
    Pagination is set to auto, and pagination results are set to show. Changing pagination to ‘show’ doesn’t seem to help 🙁
    anisjolly Friend
    #286651
    have you got a url i can look at?
    just to check – the articles are not archived?
    thealpha1 Friend
    #286653
    I should have been a bit more clear. The page links show up, however clicking on the returns no results.
    The problem is exactly like this (http://forum.joomla.org/viewtopic.php?f=430&t=325924), however no solution is posted there. To be honest, I do not think this is a Joomlart issue, and I am not sure if this happend after the 1.5.9 patch. I figured I would post it here anyway, as there is a knowledgeable crew here. 🙂
    EDIT: The articles are not archived.
    anisjolly Friend
    #286666
    cheers thealpha1
    i’ll have a look at my site and see if i can replicate it. i’ve not yet installed 1.5.9 as i’ve got a lot of backing up to do on it.
    i’ll report back (unless someone else beats me to the answer 🙂 )
    thanks for the creds 🙂 appreciate it.
    thealpha1 Friend
    #287368
    Bump… Anyone have an idea on what could even cause this?
    thealpha1 Friend
    #287371
    I found a solution……
    Change the Main Menu -> Home -> Parameters (Basic) -> # Leading from 8 to 0
    Main Menu -> Home -> Parameters (Basic) -> # Intro = 0 to 8
    This seemed to keep the same number of articles on the home page, and fixed the page 2,3,4, etc issues I was seeing. I still do not know why this occured, as it seemed to work perfectly on a previous Joomlart template.
This topic contains 8 replies, has 2 voices, and was last updated by  thealpha1 15 years, 11 months ago.
