January 5, 2017 at 3:24 pm #999956
Arvind, I am using alpha2, no external access and get a 500 similar to the above.
You may not be able to visit this page because of:
an out-of-date bookmark/favourite
a search engine that has an out-of-date listing for this site
a mistyped address
you have no access to this page
The requested resource was not found.
An error has occurred while processing your request.
Please try one of the following pages:Home Page
If difficulties persist, please contact the System Administrator of this site and report the error below.No HTTP response code found.
Call stack
Function Location
1 JApplicationCms->execute() /var/www/html/index.php:49
2 JApplicationSite->doExecute() /var/www/html/libraries/cms/application/cms.php:261
3 JApplicationSite->dispatch() /var/www/html/libraries/cms/application/site.php:230
4 JApplicationBase->triggerEvent() /var/www/html/libraries/cms/application/site.php:196
5 JEventDispatcher->trigger() /var/www/html/libraries/joomla/application/base.php:106
6 JEvent->update() /var/www/html/libraries/joomla/event/dispatcher.php:159
7 call_user_func_array() /var/www/html/libraries/joomla/event/event.php:69
8 plgSystemJabuilder->onAfterDispatch()
9 JUBHelper->getSiteid() /var/www/html/plugins/system/jabuilder/jabuilder.php:59
10 JHttp->post() /var/www/html/plugins/system/jabuilder/helper.php:73
11 JHttpTransportCurl->request() /var/www/html/libraries/joomla/http/http.php:209
12 JHttpTransportCurl->getResponse() /var/www/html/libraries/joomla/http/transport/curl.php:222Arvind Chauhan ModeratorArvind Chauhan
- 1334 times in 848 posts
January 17, 2017 at 7:35 am #1003019Thanks for your report, unfortunately, we could not replicate the issue from our side, could you please provide a screenshot highlighting the issue ?
Regards.
February 16, 2017 at 6:40 pm #1011421February 16, 2017 at 9:39 pm #1011452Hello,
I think i have the same problem.
My php is 7 try also 5.6 but i get the same problem.Saguaros ModeratorSaguaros
February 17, 2017 at 3:00 am #1011516Hi,
I can’t replicate this issue from my end unfortunately. Did you face this issue with new RC version?
Could you share the URL and Admin login info of your site so I can take a look?
February 19, 2017 at 11:13 pm #1011947This reply has been marked as private.Saguaros ModeratorSaguaros
February 21, 2017 at 5:51 pm #1012635This reply has been marked as private.Saguaros ModeratorSaguaros
February 22, 2017 at 4:12 pm #1012911Hi,
Let me check and will get back to you.
AuthorPostsThis topic contains 23 replies, has 10 voices, and was last updated by Saguaros 7 years, 10 months ago.
