November 17, 2016 at 10:29 am #987269
I’ve noticed this a while back. When I decide the order of article in a certain catagory, for exemple 4 articles called 1,2,3 and 4. when I click the article named 1, the page navigation would show ‘previous’ instead of ‘next’, and the first article actually becomes the 4th, the second the 3rd and so on.
I found out it’s because of the ‘article order’ as shown in the second attachment, if only I could have an option ‘reverse article order’, it would be ok.
Where could I regulate this issue?
Thanks.
November 18, 2016 at 3:04 am #987450Hi,
Did you try to switch default template to a standard template of Joomla like Beez / Protostar to check this pagination first?
November 18, 2016 at 8:24 am #987522Hi,
Just did that, did not work AT ALL.
I had this horrifying message instead.Anything else we could do to reorder the articles?
November 18, 2016 at 9:08 am #987531Hi again,
I swapped the content of the article and now it’s working.
Viewing 5 posts - 1 through 5 (of 5 total)This topic contains 4 replies, has 2 voices, and was last updated by Saguaros 8 years, 1 month ago.
