May 29, 2015 at 12:08 am #737259
The menu item in Position Setting tab does not appear the ‘Display Num’ option and it also does not appear on the site http://evodiadigital.com.br/portal/ which is a clean installation of the template.
Saguaros ModeratorSaguaros
May 29, 2015 at 10:06 am #572274You can try opening the file: ROOT/templates/ja_teline_v (your default template)/html/com_content/category/blank.xml
and look for this field:
<!-- Add fields to the parameters object for the layout. -->
<fields name="params">
<fieldset name="sidebar" label="TPL_BLANK_LAYOUT_SIDEBAR">
<field name="display_num" type="text" label="Display Num" default="0"/>change the field for ‘display_num’ as above.
May 29, 2015 at 10:06 am #737311You can try opening the file: ROOT/templates/ja_teline_v (your default template)/html/com_content/category/blank.xml
June 1, 2015 at 7:25 pm #572495It worked, very good!
thank you for the help and attention:)June 1, 2015 at 7:25 pm #737531It worked, very good!
thank you for the help and attention:)melvine Friendmelvine
- August 2012
- 33 times in 9 posts
August 22, 2015 at 1:52 am #664548<em>@Saguaros 475619 wrote:</em><blockquote>You can try opening the file: ROOT/templates/ja_teline_v (your default template)/html/com_content/category/blank.xml
<field name="display_num" type="text" label="Display Num" default="0"/>change the field for ‘display_num’ as above.</blockquote>
I don’t understand, I already have these lines in the xml file :confused: and no pagination
- August 2012
August 22, 2015 at 1:52 am #746299<em>@Saguaros 475619 wrote:</em><blockquote>You can try opening the file: ROOT/templates/ja_teline_v (your default template)/html/com_content/category/blank.xml
This topic contains 24 replies, has 3 voices, and was last updated by melvine 9 years, 4 months ago.
