  • islandview Friend
    #131386
    I had some posts about pagination problems (just not showing at all!) which got marked ‘Answered’ below – but they weren’t solved – so just reposting here. Try as I might I just ca’t get Edenite to come up with any pagination.
    My original query was where is the code that makes the pagination work? I was going to see if I could spot any problems myself.
    Has ANYONE got a version of Edenite that shows pagination????
    Thanks!
    OK – Here’s my page…. http://www.condoandvilla.com/see-all-cayman-condos
    …and I’m going to try to attach 3 images as follows:
    1) Admin View of the Category Blog settings showing Pagination Options turned on.
    2) The view that results – showing there is no pagination options
    3) A different view when I change the settings to show more ‘per page’ (ie just to show there are more articles which should be getting the ‘next Page’ treatment……
    Does this help solve the issue in any way???
    Oops – My Joomlart editor won’t let me upload pics….
    #262669
    Hi acbonner !
    please use gif format for image upload and upload each image , i need view image for more detail about the problem.
    islandview Friend
    #262755
    Yippee! All is now resolved. Actually the wonderful Joomlart template is in the clear – It was Joomla itself!!!! I just upgraded from 1.5.4 to 1.5.5 and that fixed what they call the ‘pagination bug’ – I now have pagination at last!!!!!!
    #262770
    Ok ! i will mark this thread to “solved”.
This topic contains 4 replies, has 2 voices, and was last updated by  Sherlock 16 years, 5 months ago.
