  • sakari Friend
    #173394
    Hello friends,
    have a problem with the “Parameter (JA Extended)”! (Joomla 2.5.0) (JA T3 System plugin v1.6.0 )
    When I entered an HTML code, it will not be saved! (see pictures)
    I brought everything up to date and yet it does not work!
    Under configuration – Text filter – Super Users – I have “No filtering” set!
    Can someone help me since then?
    Thanks in advance
    regards
    1. parameters1
    2. parameters2
    sakari Friend
    #436561
    I have tried it with Joomla 1.5 and 1.7!
    It only works in Joomla 1.5
    In Joomla 1.7 and 2.5 it does not work!
    And the template is not the problem!
    This issue should probably be in the “JAT3 2.0 for Joomla 1.7” moved!
This topic contains 2 replies, has 1 voice, and was last updated by  sakari 12 years, 9 months ago.
