Viewing 15 posts - 1 through 15 (of 19 total)
  • bvk1987 Friend
    #191415
    Hi there,
    I just installed a new Fixel template on a new website. The J-Blog however is not complete it seems. The “who’s online”, the “About Fixel”, the adverts and the categories columns are missing on the page eventhough they are selected to be viewable on the blog.
    Any ideas?
    edit:
    Also, if I “unpublish” articles, they are still shown in the front-end. Only when I delete the articles, they are not shown anymore. On my other Fixel website, unpublishing works perfectly..
    edit 2:
    How can I remove the drop down menu on top of the page? That little thing completely on the top right.
    Ninja Lead Moderator
    #509259
    I have enabled and set caching to: No caching in About Fixel module. For other problems you can follow to my below solution
    + Who’s online, see the config
    + Remove drop-down top menu
    Open templates/ja_fixel/css/themes/light/template.css file
    From
    #fixel-top-pannel-link {
    background-color: #f2f2f2;
    border-color: #E7E7E7;
    Change to
    display:none;
    1. who_online
    2. front-end
    bvk1987 Friend
    #509329
    Thank you, but I am working on a different site. That site has the problems I mentioned. Not the one you checked 🙂
    bvk1987 Friend
    #509345
    Making changes to the template.css caused strange problems with the logo dimensions and the location and color of the main menu. Therefore, I will leave the drop-down menu as is.
    However, I am still looking for a solution for the missing blog items as mentioned in my first post. “About Fixel”, “Who’s online” and “Category” are still missing on my newest website.
    I noticed that I only have 12 css files in t3-assets/css in comparison to 30 css files on my other Fixel website. Is that normal?
    #509352
    If you want to remove drop-down menu on new site you can use this way
    Open templates/ja_fixel/tpls/blocks/header.php file
    Find and remove this line
    <a href="#fixel-top-panel" id="fixel-top-pannel-link" class="top-pannel-link t3-hide" aria-hidden="true">
    <i class="icon-chevron-down"></i>
    </a>
    Other problem you can pm me admin access of your site. I shall help you to check it.
    bvk1987 Friend
    #509363
    You have them now!
    bvk1987 Friend
    #509375
    Another question. I have a few articles in the blog. They are featured. However, they are not seen on the home page. Other articles can be made visible when they are featured, but not blog articles? What can I do about this?
    #509428
    I have spent a lot of my time to check the problem on your site, because on your site, the menu is set with wrong JA Template styles. I helped you to set it:
    Please check and let me know if it helps
    1. ja_fixel_default
    bvk1987 Friend
    #509471
    Thank you, it looks great now. I had changed that setting to Home – Light because of the different colors. My other Fixel website is set to Home – Light and works fine. But I am very glad you found the problem!
    Can you help me with the question I had in my previous post? I would like to have the featured blog articles on the home page. However, this does not work. Articles in other categories do get placed 🙂
    bvk1987 Friend
    #509748
    Do you have an idea about this Ninja Lead?
    #509816
    I have received some PM from you with many site and I’m not so clear of which site I need to check. You can clarify me URL of that site. I shall check it from back-end site.
    bvk1987 Friend
    #509886
    You can disregard my previous PM’s. Just read the one I will send you now 🙂
    bvk1987 Friend
    #509892
    I solved the problem. At the menu, go to the tab Advanced Options. At Select Categories, you have the select the categories that you want to be displayed. My folder was not in there, now it is! 😀
    However, when I have set the article “Content Type” on image, the article opens and I only see the title. No text. How can that be changed?
    Also, I prefer it to link to the blog instead of opening a new window.
    #510105
    That’s great, excellent
    Content Type: Image doesn’t support to show text in the details page if you are a developer, you can customize this way
    Open templates/ja_fixel/html/com_content/article/default_popup_images.php file
    Delete the content and then paste the below script in default_popup_images.php file and remember to back-up it before doing
    <?php
    * @package Joomla.Site
    * @subpackage com_content
    * @copyright Copyright (C) 2005 - 2012 Open Source Matters, Inc. All rights reserved.
    * @license GNU General Public License version 2 or later; see LICENSE.txt
    defined('_JEXEC') or die;
    // Create shortcuts to some parameters.
    $params = $this->item->params;
    $images = json_decode($this->item->images);
    $urls = json_decode($this->item->urls);
    $canEdit = $this->item->params->get('access-edit') && !JFactory::getApplication()->input->get('tmpl', '') == 'component';
    $user = JFactory::getUser();
    $aInfo = (($params->get('show_author') && !empty($this->item->author )) ||
    ($params->get('show_category')) ||
    ($params->get('show_create_date')) ||
    ($params->get('show_parent_category')) ||
    ($params->get('show_publish_date')));
    $exAction = ($canEdit || $params->get('show_print_icon') || $params->get('show_email_icon'));
    <?php if (!empty($this->item->pagination) && $this->item->pagination && !$this->item->paginationposition && $this->item->paginationrelative) : ?>
    <?php echo $this->item->pagination; ?>
    <?php endif; ?>
    <!-- Article -->
    <article>
    <?php if ($params->get('show_title')) : ?>
    <header class="article-header clearfix">
    <h1 class="article-title">
    <?php if ($params->get('link_titles') && !empty($this->item->readmore_link)) : ?>
    <a href="<?php echo $this->item->readmore_link; ?>"> <?php echo $this->escape($this->item->title); ?></a>
    <?php else : ?>
    <?php endif; ?>
    </h1>
    </header>
    <?php endif; ?>
    <?php if($aInfo) :?>
    <!-- Aside -->
    <aside class="article-aside clearfix">
    <?php if ($aInfo) : ?>
    <dl class="article-info pull-left">
    <dt class="article-info-term"><?php echo JText::_('COM_CONTENT_ARTICLE_INFO'); ?></dt>
    <?php if ($params->get('show_publish_date')) : ?>
    <dd class="published">
    <?php echo JText::sprintf('FIXEL_COM_CONTENT_PUBLISHED_DATE_ON', JHtml::_('date', $this->item->publish_up, JText::_('DATE_FORMAT_LC3'))); ?>
    </dd>
    <?php endif; ?>
    <?php if ($params->get('show_create_date')) : ?>
    <dd class="create">
    <?php echo JText::sprintf('FIXEL_COM_CONTENT_CREATED_DATE_ON', JHtml::_('date', $this->item->created, JText::_('DATE_FORMAT_LC3'))); ?>
    </dd>
    <?php endif; ?>
    <?php if ($params->get('show_author') && !empty($this->item->author )) : ?>
    <dd class="createdby">
    <?php
    $author = $this->item->created_by_alias ? $this->item->created_by_alias : $this->item->author;
    <?php if (!empty($this->item->contactid) && $params->get('link_author') == true): ?>
    <?php
    $needle = 'index.php?option=com_contact&view=contact&id=' . $this->item->contactid;
    $menu = JFactory::getApplication()->getMenu();
    $item = $menu->getItems('link', $needle, true);
    $cntlink = !empty($item) ? $needle . '&Itemid=' . $item->id : $needle;
    <?php echo JText::sprintf('FIXEL_COM_CONTENT_WRITTEN_BY', '<span>'.JHtml::_('link', JRoute::_($cntlink), $author).'</span>'); ?>
    <?php else: ?>
    <?php echo JText::sprintf('FIXEL_COM_CONTENT_WRITTEN_BY', '<span>'.$author.'</span>'); ?>
    <?php endif; ?>
    </dd>
    <?php endif; ?>
    <?php if ($params->get('show_category')) : ?>
    <dd class="category-name">
    <?php $title = $this->escape($this->item->category_title);
    $url = '<a href="'.JRoute::_(ContentHelperRoute::getCategoryRoute($this->item->catslug)).'">'.$title.'</a>';?>
    <?php if ($params->get('link_category') and $this->item->catslug) : ?>
    <?php echo '',JText::sprintf('FIXEL_COM_CONTENT_CATEGORY',''.$url); ?>
    <?php else : ?>
    <?php echo '<span class="name">',JText::sprintf('FIXEL_COM_CONTENT_CATEGORY','</span>'.$title); ?>
    <?php endif; ?>
    </dd>
    <?php endif; ?>
    <?php if ($params->get('show_parent_category') && $this->item->parent_slug != '1:root') : ?>
    <dd class="parent-category-name">
    <?php
    $title = $this->escape($this->item->parent_title);
    $url = '<a href="'.JRoute::_(ContentHelperRoute::getCategoryRoute($this->item->parent_slug)).'">'.$title.'</a>';
    <?php if ($params->get('link_parent_category') and $this->item->parent_slug) : ?>
    <?php echo JText::sprintf('FIXEL_COM_CONTENT_PARENT', $url); ?>
    <?php else : ?>
    <?php echo JText::sprintf('FIXEL_COM_CONTENT_PARENT', $title); ?>
    <?php endif; ?>
    </dd>
    <?php endif; ?>
    <?php if($this->item->event->afterDisplayTitle && stripos($this->item->event->afterDisplayTitle, 'count') !== false): ?>
    <dd>
    <?php echo $this->item->event->afterDisplayTitle; ?>
    </dd>
    <?php endif; ?>
    </dl>
    <?php endif; ?>
    </aside>
    <!-- //Aside -->
    <?php endif; ?>
    <?php if (isset ($this->item->toc)) : ?>
    <?php echo $this->item->toc; ?>
    <?php endif; ?>
    <?php if (!$params->get('show_intro')) : ?>
    <?php endif; ?>
    <?php if (isset($urls) && ((!empty($urls->urls_position) && ($urls->urls_position=='0')) || ($params->get('urls_position')=='0' && empty($urls->urls_position) )) || (empty($urls->urls_position) && (!$params->get('urls_position')))): ?>
    <?php echo $this->loadTemplate('links'); ?>
    <?php endif; ?>
    <?php if ($params->get('access-view')):?>
    <?php if (isset($images->image_fulltext) && !empty($images->image_fulltext)) : ?>
    <?php
    $imgfloat = (empty($images->float_fulltext)) ? $params->get('float_fulltext') : $images->float_fulltext;
    <div class="pull-<?php echo htmlspecialchars($imgfloat); ?> item-image">
    <img
    <?php if ($images->image_fulltext_caption): ?>
    <?php echo 'class="caption"'.' title="' .htmlspecialchars($images->image_fulltext_caption) .'"'; ?>
    <?php endif; ?>
    src="<?php echo htmlspecialchars($images->image_fulltext); ?>" alt="<?php echo htmlspecialchars($images->image_fulltext_alt); ?>"/>
    </div>
    <?php endif; ?>
    <?php
    if (!empty($this->item->pagination) AND $this->item->pagination AND !$this->item->paginationposition AND !$this->item->paginationrelative):
    endif;
    <section class="article-content clearfix" <?php if(!$this->item->event->beforeDisplayContent): echo 'style="margin-left: 0"'; endif; ?>>
    <?php echo $this->item->text; ?>
    <?php $useDefList = (($params->get('show_modify_date')) or ($params->get('show_hits'))); ?>
    <?php if ($useDefList) : ?>
    <footer class="article-footer clearfix">
    <?php if ($params->get('show_modify_date')) : ?>
    <dd class="modified">
    <?php echo JText::sprintf('COM_CONTENT_LAST_UPDATED', '<span>'.JHtml::_('date', $this->item->modified, JText::_('DATE_FORMAT_LC3')).'</span>'); ?>
    </dd>
    <?php endif; ?>
    <?php if ($params->get('show_hits')) : ?>
    <dd class="hits">
    <?php echo JText::sprintf('COM_CONTENT_ARTICLE_HITS', '<span>'.$this->item->hits.'</span>'); ?>
    </dd>
    <?php endif; ?>
    </dl>
    </footer>
    <?php endif; ?>
    <?php
    if (!empty($this->item->pagination) && $this->item->pagination && $this->item->paginationposition && !$this->item->paginationrelative): ?>
    <?php
    echo '<hr class="divider-vertical" />';
    <?php endif; ?>
    <?php if (isset($urls) && ((!empty($urls->urls_position) && ($urls->urls_position=='1')) || ( $params->get('urls_position')=='1') )): ?>
    <?php endif; ?>
    <?php //optional teaser intro text for guests ?>
    <?php elseif ($params->get('show_noauth') == true and $user->get('guest') ) : ?>
    <?php echo $this->item->introtext; ?>
    <?php //Optional link to let them register to see the whole article. ?>
    <?php if ($params->get('show_readmore') && $this->item->fulltext != null) :
    $link1 = JRoute::_('index.php?option=com_users&view=login');
    $link = new JURI($link1);
    <section class="readmore">
    <a href="<?php echo $link; ?>">
    <span>
    <?php $attribs = json_decode($this->item->attribs); ?>
    <?php
    if ($attribs->alternative_readmore == null) :
    echo JText::_('COM_CONTENT_REGISTER_TO_READ_MORE');
    elseif ($readmore = $this->item->alternative_readmore) :
    echo $readmore;
    if ($params->get('show_readmore_title', 0) != 0) :
    echo JHtml::_('string.truncate', ($this->item->title), $params->get('readmore_limit'));
    endif;
    elseif ($params->get('show_readmore_title', 0) == 0) :
    echo JText::sprintf('FIXEL_COM_CONTENT_READ_MORE_TITLE');
    else :
    echo JText::_('FIXEL_COM_CONTENT_READ_MORE');
    endif; ?>
    </span>
    </a>
    </section>
    <?php endif; ?>
    <?php endif; ?>
    </section>
    <?php if ($params->get('show_tags', 1) && !empty($this->item->tags->itemTags)) : ?>
    <?php $this->item->tagLayout = new JLayoutFile('joomla.content.tags'); ?>
    <div class="view-tags"><i class="icon-tag"></i>
    <?php echo $this->item->tagLayout->render($this->item->tags->itemTags); ?>
    </div>
    <?php endif; ?>
    </article>
    <!-- //Article -->
    <div class="list-icons">
    <?php echo $this->item->event->beforeDisplayContent; ?>
    <?php if ($params->get('show_print_icon') || $params->get('show_email_icon') || $canEdit) : ?>
    <div class="menu-edit">
    <ul class="clearfix">
    <?php if (!$this->print) : ?>
    <?php if ($params->get('show_print_icon')) : ?>
    <li class="print-icon"> <?php echo JHtml::_('icon.print_popup', $this->item, $params); ?> </li>
    <?php endif; ?>
    <?php if ($params->get('show_email_icon')) : ?>
    <li class="email-icon"> <?php echo JHtml::_('icon.email', $this->item, $params); ?> </li>
    <?php endif; ?>
    <?php if ($canEdit) : ?>
    <li class="edit-icon"> <?php echo JHtml::_('icon.edit', $this->item, $params); ?> </li>
    <?php endif; ?>
    <?php else : ?>
    <li class="print-icon"> <?php echo JHtml::_('icon.print_screen', $this->item, $params); ?> </li>
    <?php endif; ?>
    </ul>
    </div>
    <?php endif; ?>
    </div>
    <?php if (!empty($this->item->pagination) && $this->item->pagination && $this->item->paginationposition && $this->item->paginationrelative): ?>
    <?php endif; ?>
    bvk1987 Friend
    #510202
    Thank you Ninja Lead. I chose to use Content Type – Social.
    In order to get directed from the home page article straight to the blog (instead of a new window opening), you have to go to Template Manager and change at General the Pop-up view.
    Somehow the facebook plugin in not positioned beneath the blog articles anymore. Also, the buttons in the left bar next to the article does not show the “facebook”, “twitter” etc buttons (beneath e-mail and print). Do you know what happened there?
This topic contains 19 replies, has 2 voices, and was last updated by  bvk1987 11 years, 1 month ago.
