7of9 Friend
7of9
- December 2010
- 25 times in 3 posts
February 12, 2018 at 4:25 pm #1091559Hi,
I started to get error, Parts of the page are not secure for one of my websites.
Please advise.Thank you in advance.
February 15, 2018 at 4:03 am #1091954Hi
The homepage of your site does not show any error of mixed content.
Please share the details on which page you are facing the error, So I can check it.Regards
7of9 Friend7of9
- December 2010
February 15, 2018 at 8:40 pm #1092175Pankaj Sharma ModeratorPankaj Sharma
February 16, 2018 at 2:51 am #1092180Hi
its from the Module: mod_fpss/
That is generating non SSL links: http://prntscr.com/ifehsd
Kindly check the module options and if there is no such option to change links report it to module provider.Regards
7of9 Friend7of9
- December 2010
February 21, 2018 at 11:08 pm #1093086Pankaj Sharma ModeratorPankaj Sharma
February 22, 2018 at 2:04 am #1093099Hi
Its working fine now, only the error is from Shopping component
/components/com_jshopping/images/xstar.png.pagespeed.ic.STDwqcy5Mn.png
Its loading from the component.
For the logo error, kindly take backup of site, update T3 and template to the latest version.Turn of Development mode and upload logo from template options.
7of9 Friend7of9
- December 2010
February 22, 2018 at 4:32 am #1093142It does not seem to be working. Please take a look at my screen shot.
Also about the problem of the Shopping component
I did not understand how to fix that.I would appreciate any help.
February 22, 2018 at 4:54 am #1093152Hi
I checked your site and T3 is not updated Yet : http://prntscr.com/ii4d2o
Please check.For the Joomshopiing and the module its from the module, please post the issue to extension provider as its something from the extension not from a template.
7of9 Friend7of9
- December 2010
February 22, 2018 at 1:09 pm #1093243Hi,
I updated T3, still having the same issue. Please advise.
PS: I have a backup, so if you need to change something, please do, but please keep me posted. I would appreciate this to be resolved soon, since I am running out of time.
- This reply was modified 6 years, 9 months ago by 7of9.
February 23, 2018 at 2:05 am #1093368Hi
The issue is already fixed for the logo http://prntscr.com/iik6hf
And site showing secure : http://prntscr.com/iik6k9Kindly check, If you are getting error from the 3rd party extension (its not showing my side) I suggest you to report them to extension provider.
7of9 Friend7of9
- December 2010
February 23, 2018 at 3:40 pm #1093542Pankaj Sharma ModeratorPankaj Sharma
February 26, 2018 at 2:12 am #1093799Hi
I already suggested you to update template and T3 and disable the development mode from template options. Still, you have not updated the template to 1.1.7
http://prntscr.com/ijqms6
Kindly take backup of your custom changes and update template first.
After this compile less to css and disable the Development mode.
clear Joomla and browser cache and check the page.Also, to fix the 3rd party extension issue kindly reais the issue to extension provider its not from the template.
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 11 replies, has 2 voices, and was last updated by Pankaj Sharma 6 years, 9 months ago.
