  • kaj Friend
    #192009
    While printing a K2 article I also get path info printed after author; “Written by Super User (/index.php/products/itellist/user/42-superuser)” and under the image, please see attached file. The same with the area of the avatar of the Super User.
    The path info is not shown in the article or in preview, only when printed. Has anyone experienced this and if so, what was the solution to remove it?
    kaj
    1. path_info
    Hello kaj,
    Please try this way:
    – Create a new file named ‘custom.css‘ in templatesja_beraniscss folder (if this file doesn’t exist)
    – Add this css rule:
    @media print {
    a:after {
    display: none;
    Then try printing again and let me know how it goes.
    This thread was missed to be replied and I’m sorry for the same.
    kaj Friend
    #511715
    Saguaros, as usual, you solved the problem – thanks 🙂
    Kaj
This topic contains 3 replies, has 2 voices, and was last updated by  kaj 11 years, 1 month ago.
