  • breathwork Friend
    #166326
    My website has been running fine until approx 3 weeks ago since then it has taken upward of 2 minutes to load the front page.
    All i have done is to upgrade components, modules and plugins.
    I really need help in tracking down what is causing the problem, or move to a better host…
    Can you help me please?
    Phill Moderator
    #401344
    Which components did you upgrade when the problem occurred? It could be so many reasons that it really is going to be impossible for us to tell. You will need to work out exactly which component is causing the delay.
    breathwork Friend
    #401368
    Any suggestions about which ones to start with? Or should I just turn off everything and then turn them on one by one until I hit an issue?
    Phill Moderator
    #401385
    I would start with any modules or plugins that call external content such as rss feeds, weather modules, Facebook or twitter etc.
This topic contains 4 replies, has 2 voices, and was last updated by  Phill 13 years, 5 months ago.
