  • kalos Friend
    #143065
    I used the quickstart tutorial and I’m getting the following error on the frontpage:
    Warning: mkdir() [function.mkdir]: Permission denied in /var/www/domains/kalos.livethechange.ca/docs/templates/ja_sulfur/ja_templatetools_1.5.php on line 519
    SP Media Friend
    #312485
    Check your CHMOD settings. Just checked your site – there’s nothing there under /docs though.
    kalos Friend
    #312493
    My CHMOD settings look correct – but I’m not sure. Just to see if it helped, I gave ja_templatetools_1.5.php CHMOD 777 and also the parent folder. Not sure what directory ja_templatetools_1.5.php is trying to write to….
    kalos Friend
    #312494
    NEVERMIND – fixed it. I opened ja_templatetools_1.5.php line 519 and saw it’s pointing to the images/ folder. Fixed permissions there and everything is fine.
This topic contains 4 replies, has 2 voices, and was last updated by  kalos 15 years, 5 months ago.
