  • veltink Friend
    #142260
    Hi there,
    I am setting up a site for a band at: http://www.stoutonline.nl with JA_Zinc and while I was adjusting de slideshow I got the error message:
    Warning: imagejpeg() [function.imagejpeg]: Unable to open ‘/home/stout/domains/stoutonline.nl/public_html/images/resized/images/stories/slideshow/sl-3_150_57.jpg’ for writing: Permission denied in /home/stout/domains/stoutonline.nl/public_html/modules/mod_jaslideshow/mod_jaslideshow.php on line 320
    I cannot figure out the permission problem. I have set up several sites and compared some of the settings and they are exactly the same. Is this a Joomla problem, Zinc related or is it their provider.
    Oscar
    mayke Friend
    #309192
    Based on my experienced, have you tried to set the permission folder to 777 for the resize folder and all folders under/inside the resized folder?
    veltink Friend
    #309273
    Thanks mayke, I tried that one but it did not work. Actually I found out that I cannot change a thing anymore in the site. Only the changes stored in the database and the changes I made during connection with my ftp-client are working. If I try to change the config file throught joomla or even upload a picture throught the media manager the system says it did not succeed in carrying out the things I wanted. So maybe a permission problem in the rot of the site?
    xcrozx Friend
    #320770
    Same problem here
This topic contains 4 replies, has 3 voices, and was last updated by  xcrozx 15 years, 2 months ago.
