rvolt Friend
rvolt
- July 2015
- 6 times in 1 posts
August 8, 2015 at 2:05 am #658933I was just informed that users do not receive registration emails. I tested PHPMAIL / SENDMAIL / SMTP Mail and none work on this quickstart installation of joomla / ja_directory. I can’t figure out what is wrong, though it works on other joomla sites I have on the same hosting (dif templates)
pavit Moderatorpavit
August 8, 2015 at 10:41 am #659029Hi
Mail configuration is not managed in any way by templates files , it is a Joomla core feature.
You should ask to your hosting provider to better verify your phpmail configuration on their servers and verify through mailserver logfiles which emails are sent from their servers and verify where the whole process stop .
rvolt Friendrvolt
- July 2015
August 9, 2015 at 2:16 am #659092Whats weird is, this same version of joomla, installed on the same server, using a different template works. My hosting company doesn’t see any problem with the server. Maybe I should just copy the com_mailer folder from the working template and past it on the ja_directory quick install template ?
Does the mailer feature / quick contact work for anyone else using ja_directory ? Interested what other users are getting…
rvolt Friendrvolt
- July 2015
August 10, 2015 at 12:27 am #659228I tried to register on the demo site for this template, and didn’t get an email either. Is it not setup to send on the demo? Or is this a problem with the package overall ?
rvolt Friendrvolt
- July 2015
August 10, 2015 at 12:27 am #744926I tried to register on the demo site for this template, and didn’t get an email either. Is it not setup to send on the demo? Or is this a problem with the package overall ?
August 12, 2015 at 5:38 pm #660654<em>@rvolt 486647 wrote:</em><blockquote>I tried to register on the demo site for this template, and didn’t get an email either. Is it not setup to send on the demo? Or is this a problem with the package overall ?</blockquote>
Did you solved it ? or you still need help ?
rvolt Friendrvolt
- July 2015
August 12, 2015 at 7:55 pm #660666It is not solved. Sendmail and phpmail dont work so im using a third party smtp server. mandrill =
rvolt Friendrvolt
- July 2015
August 15, 2015 at 10:24 am #661859I wish it did work. Can you help with it ?
rvolt Friendrvolt
- July 2015
August 15, 2015 at 10:24 am #745527I wish it did work. Can you help with it ?
- November 2014
- 3854 times in 3563 posts
August 17, 2015 at 4:22 am #662271<em>@rvolt 487495 wrote:</em><blockquote>I wish it did work. Can you help with it ?</blockquote>
I need a closer look to detect the root of the issue. Please pm me the url to access backend site(now it is auto redirected to homepage), admin & ftp account of your site.
- November 2014
August 17, 2015 at 4:22 am #745614<em>@rvolt 487495 wrote:</em><blockquote>I wish it did work. Can you help with it ?</blockquote>
- November 2014
August 24, 2015 at 8:22 am #664876<em>@rvolt 487140 wrote:</em><blockquote>It is not solved. Sendmail and phpmail dont work so im using a third party smtp server. mandrill =</blockquote>
I am not sure the phpmail function on your site works or not.
But you can try to set the configuration from Global Configuration from backend on your site as user guide for reference here
- November 2014
August 24, 2015 at 8:22 am #746378<em>@rvolt 487140 wrote:</em><blockquote>It is not solved. Sendmail and phpmail dont work so im using a third party smtp server. mandrill =</blockquote>
rvolt Friendrvolt
- July 2015
August 27, 2015 at 11:56 pm #680352phpmail does work on my server and was tested in a standalone environment. This is why I’ve had to use the SMTP feature you see enabled via mandrill
phpmail works on other joomla installs on this same server. It just doesn’t work with the quickinstall I used for jadirectory
rvolt Friendrvolt
- July 2015
August 27, 2015 at 11:56 pm #746838phpmail does work on my server and was tested in a standalone environment. This is why I’ve had to use the SMTP feature you see enabled via mandrill
This topic contains 24 replies, has 4 voices, and was last updated by jooservices 9 years, 3 months ago.
