Ninja Lead Moderator
Ninja Lead
- November 2014
- 3854 times in 3563 posts
August 28, 2015 at 2:25 am #680367<em>@rvolt 489437 wrote:</em><blockquote>phpmail does work on my server and was tested in a standalone environment. This is why I’ve had to use the SMTP feature you see enabled via mandrill
phpmail works on other joomla installs on this same server. It just doesn’t work with the quickinstall I used for jadirectory</blockquote>
Please pm me ftp account of your site. I will help you to detect this directly on your site.
- November 2014
August 28, 2015 at 2:25 am #746853<em>@rvolt 489437 wrote:</em><blockquote>phpmail does work on my server and was tested in a standalone environment. This is why I’ve had to use the SMTP feature you see enabled via mandrill
rvolt Friendrvolt
- July 2015
- 6 times in 1 posts
August 31, 2015 at 12:09 am #680779sent thank you
rvolt Friendrvolt
- July 2015
August 31, 2015 at 12:09 am #747008sent thank you
- November 2014
August 31, 2015 at 9:40 am #680912<em>@rvolt 489767 wrote:</em><blockquote>sent thank you</blockquote>
I tested with phpmail code directly on your site and it’s working fine, I tested the phpmail setting with quickstart package from our local and it’s working as well, about the problem with configuration phpmail setting from backend site, you can contact with hosting system provider to get the log error and beside you can raise that bug to joomla forum maybe you will get best answer from there.
- November 2014
August 31, 2015 at 9:40 am #747091<em>@rvolt 489767 wrote:</em><blockquote>sent thank you</blockquote>
rvolt Friendrvolt
- July 2015
August 31, 2015 at 11:06 am #747096Have you tried registering on my page ? Nobody ever gets the email with PHPMail set. I registered again after you set it to phpmail and no address I try receives mail. I’ve posted on joomla’s main forum and never get an answer that works. I check spam folders too, so its weird. The phpmail function works on the server, just not my install…
Also my hosting has tested phpmail function and it worked outside of this installation. Just nobody receives email when registering
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
August 31, 2015 at 12:09 pm #680957Hi there
You can verify it by.
# Install JA quickstart
# Install Joomla! Quickstart
# A single php file with php mail callAnd of course on same server.
# Check with JA Quickstart
# Check with Joomla! Quickstart
# And finally check it php mail in single php fileCheck your server log if php mail already executed and email already sent out.
If it’s already send out than it’s mean php mail works . Please note send out does not mean users will receive it.Actually i have faced lots of troubles with php mail, specially from cheap hosting provider.
# Email already be blocked by receiver ( like google ) . Than, of course, users will not receive it even in spam mail.Thank you,
Viet Vujooservices Friendjooservices
- October 2014
August 31, 2015 at 12:09 pm #747099Hi there
Viet Vu -
This topic contains 24 replies, has 4 voices, and was last updated by jooservices 9 years, 4 months ago.
