ew128 Friend
ew128
- October 2011
- 2 times in 1 posts
March 4, 2013 at 10:37 am #185497Hello,
I added new picture in #ja-header and normally it’s ok.
Problem is when i will change page scale because pictures in body#bd overlap in to picture in #ja-header
Please look to the attached picture.
How to fix it?
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
March 4, 2013 at 5:28 pm #485285It looks to me that your logo image ( see here ) may be a bit too long (length-wise).
I am not 100% certain how you want your header section to look – with the two images to the far right. If the spacing of the two images to the right are what you want – save for the overlap – then I suppose you could try adding a “z-index” property to the CSS rule for the image of the coin – for example . . .
Within file path –> /templates/ja_university/css/template.css
at line 917 . . .
#ja-header {
background-attachment: scroll;
background-clip: border-box;
background-image: url("../../../images/10940177.jpg");
background-origin: padding-box;
background-position: 99% 83%;
background-repeat: no-repeat;
border-bottom: 1px solid #000000
z-index: 999;
}See if that might work out for you. Otherwise, I would suggest reducing the overall length of your logo image just a bit.
Hope that helps
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by TomC 11 years, 10 months ago.
picture in body overlap picture in header
