Viewing 15 posts - 1 through 15 (of 21 total)
  • minas69 Friend
    #152172
    Hi all,
    I have a big big question ๐Ÿ™‚
    I already bought a Multimedia background. Know I want to place this background in the Ja_Teline debug position like a normal background picture but I really dont know what I have to do ..step..by step…:confused:confused:
    Here you can find the link to see which background and which files I got.:
    http://activeden.net/item/multimedia-background-with-slideshow-/110801
    What I have to do ?! step by step…..
    thanks for your comment and help
    mina
    uniquebiz Friend
    #348527
    I’d expect you publish it to that position? Looking at the website you brought it from seems there is a support area for members try ther or read the documentation that comes with it, it says it is well documented? But as a non member I cannot see more than what is on the sales page. Their product they should advise and provide support
    minas69 Friend
    #348530
    no..it is not well documented..only the different modify things regarding config.xml…..
    ok..you are right.. Iยดll try first this way ๐Ÿ™‚
    When I have no solution..I will come back to you…( hope you agree ;))
    thanks….
    mina
    minas69 Friend
    #348543
    So.. Iยดm back ๐Ÿ™‚
    Just talked with the coder but he has no experience with Joomla and which code I have to use to include Flash as a background movie behind the frontpage……
    What we can do ?!
    mina
    uniquebiz Friend
    #348558
    It’s very hard to know, Mina, without knowing how the thing works, is it a component or a module? If a module you should just fill in a url of the video to be displayed or insert the video to the module much the same as all the other video players and publish to a position.
    Let’s look at the ‘normal’ method of getting a flash based video into Joomla, using most module based display modules, you find the flash code and embed it into your article or module, looking at YouTube for a real world application you go to youtube, find your preferred video click on share button to reveal url, copy and paste this url into proper field for urls to stream the video to your site,
    the other parameters a such as video height, width generally are automatically set when video streams.
    IF You Use JCE editor it has an optional paid for Media object and Media manager that allows you to drop videos into articles etc
    while I understand you can’t give us a live example till you figure how to use it ๐Ÿ™‚ but please take a screen shot of the the module panel so we can see what you have to fill in etc that may help us solve it
    Blessings Shannon
    minas69 Friend
    #348566
    Dear Shannon…
    I will explain to you as follow :
    I got these files – please see picture one ๐Ÿ™‚
    I already copied everything via FTP to the main root directory …..
    Now..when I start my webadress in the browser I see the Flash animation inFull Screen Mode…and I think that my original frontpage is now behind the Flash animation……
    I found out that the can use Flash in background with the code “wmode” and “Transparent” or “opaque” and checked the index.html code- see below :
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
    <head>
    <style type="text/css">
    html,body,object,embed {
    margin: 0px;
    padding: 0px;
    border: 0px;
    width: 100%;
    height: 100%;
    overflow: hidden;
    </style>
    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-2" />
    <title>thesunshine</title>
    <script language="javascript">AC_FL_RunContent = 0;</script>
    <script src="AC_RunActiveContent.js" language="javascript"></script>
    </head>
    <body bgcolor="#cccccc">
    <!--url's used in the movie-->
    <!--text used in the movie-->
    <!-- saved from url=(0013)about:internet -->
    if (AC_FL_RunContent == 0) {
    alert("This page requires AC_RunActiveContent.js.");
    } else {
    AC_FL_RunContent(
    'codebase', 'http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0',
    'width', '100%',
    'height', '100%',
    'src', 'preview',
    'quality', 'high',
    'pluginspage', 'http://www.macromedia.com/go/getflashplayer',
    'align', 'middle',
    'play', 'true',
    'loop', 'true',
    'scale', 'showall',
    'wmode', 'window',
    'devicefont', 'false',
    'id', 'preview',
    'bgcolor', '#cccccc',
    'name', 'preview',
    'menu', 'true',
    'allowFullScreen', 'true',
    'allowScriptAccess','sameDomain',
    'movie', 'preview',
    'flashvars', 'path=xml/config.xml',
    'salign', ''
    ); //end AC code
    </script>
    <noscript>
    <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0" width="100%" height="100%" id="preview" align="middle">
    <param name="allowScriptAccess" value="sameDomain" />
    <param name="allowFullScreen" value="true" />
    <param value="transparent" name="wmode" />
    <param name="flashvars" value="path=xml/config.xml" />
    <param name="movie" value="preview.swf" /><param name="quality" value="high" /><param name="bgcolor" value="#cccccc" /> <embed src="preview.swf" <param name="flashvars" value="path=xml/config.xml"/> quality="high" bgcolor="#cccccc" width="100%" height="100%" name="preview" align="middle" allowScriptAccess="sameDomain" allowFullScreen="true" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" />
    </object>
    </noscript>
    </body>
    </html>
    Then I already changed the wmode – window to transparent ..but it is still in front…
    So what I have to do ????
    It can be that iยดm totally wrong and there is a easy solution to cover this….?!?
    Many thanks….
    Mina
    1. 1
    Phill Moderator
    #348567
    So you are just trying to set a swf file as your background?
    uniquebiz Friend
    #348582
    It appears to be the case, I have assumed the download was a module based way to insert a swf at the debug position and related my reply along those lines
    minas69 Friend
    #348635
    Yes this slideshow wiht images and swf videos Phil ….!
    minas69 Friend
    #348636
    and now ๐Ÿ™‚ !?
    uniquebiz Friend
    #348777
    If you wish your frontpage to show and not the swf you need to put the swf in a module and publish to a position, if you want the swf to show but not full page size reduce the height =100% and width=100% to allow other stuff to show
    minas69 Friend
    #348795
    mh.. it seems that it is really a little bit difficult… I tried to place the swf in a custom modul position same like my logo swf but you cant see the swf only a black or a blank case. I used for this only the preview.swf. Then I downloaded ” the flash modul ” but with the same result.
    I made a picture what I want to do to understand it easier because your suggestion above explain 2 different things…please see picture ( swf behind the frontpage like a background – picture )…
    1. 23
    uniquebiz Friend
    #348801
    Hi Minas
    I can’t really see the area you are describing well on the screenshot, if you’re web site is live on the net please give me the url and I should go there and see for myself, I am getting the impression you may be trying to insert the swf in to the ja news component rather than the normal module area?
    I’m sure with some patience and good communication I can be of help to you
    Blessings Shannon
    minas69 Friend
    #348810
    Oh Shannon you are really kindly ๐Ÿ™‚ thanks for that…
    The webadress is : http://www.thesunshine.de ( positive news magazine )
    There you can see the blue background colour. Instead of this background colour behind the template I want to place the flash file I already bought !
    thanks…
    mina
    Phill Moderator
    #348811
    For what you are trying you will have to apply code directly to the template and not in a module position. There is no module position for the background.
    Look in templates>la_teline_iii>layouts>default.php for the following
    <body id="bd" class="fs<?php echo $this->getParam(JA_TOOL_FONT);?> <?php echo $this->browser();?>">
    and insert your custom swf code in there. I haven’t time nor a suitable swf file to work out the code for you.
This topic contains 21 replies, has 3 voices, and was last updated by  minas69 14 years, 5 months ago.
